Goal
Modify my SS Agile to be comfortable for hot and cold weather plus run 2 refrigerators 24 hours and normal running equipment by solar. Batteries to float each day
To Do List modified 7/16 from Original
Run Network wires - Modem Router - switch etc.
Locate UPS for Direct TV for Electronics
Run Two Direct TV Cables plus Winegaurd switch
Seal Cables in roof
Install Maxxair behind Air Conditioner - exhaust or intake pro's and cons roof vents -
https://sprinter-source.com/forums/showthread.php?p=314902#post314902
Fantastic mounted toward front - exhaust only
Run 12 volt wire system separate from Factory installed
Relocate plug for air conditioner and install temperature on\off (hein - 2010 3500 RV build)
Insulate Agile (Thinsulate - Reflectix - Cool max Dynamat - using FatMat (hein - 2010 3500 RV build) (purchased Thinsulate from hein)
Finalize Magnum Hybrid already installed with Midnite solar controller
install manual cut off switches
install Magnum Smart Battery Combiner (ME-SBC) - (hein - 2010 3500 RV build)
install 2 slot wire ducts across ceiling for additional wiring
remount 1/4 inch plywood leather covered ceiling
reinstall cabinets thinking about ventilation between
Work on bicycle mount in place of rear top storage cabinet
Phase 2
Solid Mount 7 Solar panels on the Roof. Work on adding 6 more mounted off the side when Stationary - some kind of hinge system that is easy to remove. These 100 watt panels weigh 3 lbs each.
Looking from the back RH Side bed with cabinets underneath (open from top) fold out into isle to make double bed
Looking from the back LH Side
http://www.amazon.com/Whynter-FM-62...2-spell&keywords=Whynter+12+volt+refrideraors
2nd refrigerator (purchased 2 years ago for $600 - wow has that gone up in price!), works great) with cabinets under neath between Hot water heater and Furnace
Enclose batteries that were mounted underneath the rear back (6) now near slide out - shorter wire to inverter and better weight balance , possible trailer in the future or small car tow
Final
Take to Local Sprinter Suspension specialist for the best Modifications for the balance of weight
