TV Sprinter
I have 2 separate but possibly related problems with my Espar unit and my REST system.
1. The coolant pump (REST) isn't working properly. It will activate when the van is cold, but sounds like it's having trouble pumping. When the van has been driven and then shut off, it won't activate. I suppose this pump will need to be replaced - does anyone know the part #? (EDIT: see below)
2. My engine heater (Espar unit) is not working as well. I think I caused this....
Last winter, I had the hood open with the engine running and was cleaning salt off the motor / engine compartment with water. The Espar unit was on - and I mistakenly shot some water in the air intake (you know, the one with the huge NO WATER sticker on it ).
About 10 seconds after realizing I got water in the main intake, the Espar started billowing smoke. I assume that I damaged the unit - at least the glow plug. From the Espar website, the unit has replacable parts. I am going to attempt to repair it instead of replacing the entire unit - must be $1000 at the dealer
My second question is - does the Espar know the coolant pump isn't working? Perhaps that is preventing it from firing - assuming I didn't destroy anything in the Espar? I also haven't tried to re-prime the Espar fuel pump... will attempt that first.
Thanks in advance for replies -
Also - troubleshooting guide... http://www.espar.com/documents/airtronic_hydronic_troubleshooting.doc
Possible recirculating pump part # - MB A0018351364 Dodge 05098398AA - PUMP RECIRCULATING
