20160830 Added:
Posts considered off-topic may be deleted without notice. Post repair questions elsewhere.
I'm trying to get my head around what constitutes LHM. I know, or think I know, that there are different levels of LHM. The transmission only allowing 2nd gear and reverse operation is the most severe level. One of the questions is often whether the computer(s) have set LHM or if it is just a regular old component failure causing a regular old lack of power.
Some recent discussion got me thinking that there may be simple checks to determine if you are having a computer set LHM incident.
"Emergency Running Mode" limits to 3200 RPM. That must be "Limp-in Mode" or "Limp Home Mode" as I've seen the various descriptors used even in MB "official" publications.
So-o-o, I'd like to start an incident log in the form of this thread. It may not be the best method, but unless someone comes up with a better idea this is what we got.
Should you experience a lack of power please try raising the engine speed before you shut down the engine. If the engine will not go above about 3200 RPM, you are most likely in a computer set LHM. If the engine readily goes above that RPM you are most likely not in a LHM mode. After you determine whether you actually were in LHM or not, and you resolve your problem(s), please post what you found here.
A description of symptoms, DTC's found, etc. would be very helpful. Please don't clutter up this thread by asking questions specific to your present problems.
By the way. A problem with the Fuel Rail Pressure Sensor may limit to 2800 RPM. The difference between 2800 and 3200 RPM should be noted when doing the engine speed test.
We'll see how this thread progresses. Maybe it will just die quietly. vic
