surlyoldbill
I posted about the modified glow plug modules I make a while back. I get emails that ask the same questions, so here's the scoop.
They are modified to allow external fuses instead of the hard-wired internal fuses, which are bypassed. When a GP fuses to ground or has too high a draw, the external fuse for that particular GP is blown, not the entire module. This cuts costs ( 10 cents instead of $87+) AND shows you which GP is having a problem without having to run a diagnostic or set up a makeshift wiring device to test each individual plug.
This probably voids any warranty on effected systems, I don't know.
They take about 15 minutes to install unless you can contort and do it without taking out the battery tray.
They cost a little under $100, and I need the old module as a core, or a deposit for the cost of a used module.
I use all new wire, fuse block and fuses. The module is a used OEM GP module/relay.
They work with 2002-2006 2.7l engines (OM612 and OM647).
Sorry about such a blatant ad, I wanted to be subtle before but had to field the same questions, especially about price, all the time.
