My 2004 doesn't have a map or diagram which lists what the various relay positions are under the seat.
This is the relay block.
I traced the Electric Auxiliary Fan relay for the A/C condenser to position #4 by using wire colors.
Even though they claim the positions vary by options ordered, I'd appreciate it if someone could scan or photograph a relay map from a 2004 and post it here. At least then I can have a place to start checking for wire colors to identify my relays.
Perhaps some different year maps will help others too. Thanks in advance. vic
There's more info here.
Fuse Block #2 Fuse Map 2004 some 2006
I've had some problems interpreting my Fuse Map for the Fuse Block #2 under the driver seat. I can be dense sometimes though. I think I've figured some things out. The listings on the right side refer to the relay rails under the seat cushion. The similar nomenclature on many of the listings can...
sprinter-source.com
