How to fix water pooling in shower pan?
Hey ya'll, I know a lot of us suffer this issue of water pooling in our shower pans. Many van shower pans are flat, and even sloped pans pool water if you're not parked on a level surface.
Does anyone have a solution for this?
Current idea is a shower mat that wicks & evaporates the water in the bottom, has anyone tried this?
RVBarry
2023 AWD 170 DIY CamperVan
The best solution is a slightly convex shower pan (curves upwards to the center), with 2 or more drains in opposite corners.
However, it seems to be impossible to source them outside EU, unless you want to make one yourself.
I could never get all of the water down the drain and then needed to wipe up with a rag
That is so smart... this is definitely the most right solution I've heard of.
kcshoots
VanTripping.com
I just wonder what's the big deal with a little water pooling in the shower pan? Once you start driving doesn't the water work its way into the drain with the movement of the van underway?
