Reset the SRS System / Light without a scanner
K1nslayer
Hello All,
I found this information useful when I was working under the drivers seat and forgot to disconnect the battery. I have since purchased a scanner, but I can confirm that this worked on a 2010 2500 Freightliner Sprinter. I searched first, but only saw posts of people asking for info/help. Appologies if this information is already in the forum somewhere or if this is the wrong location to post it.
How to Reset the SRS Light on a NCV3 Sprinter Van. Without using a scanner!
* Put the key into the ignition and turn the switch to the "on" position.
* Watch for the airbag light to turn on. It will stay illuminated for seven seconds and then shut itself off. After it shuts off, immediately turn the switch off and wait three seconds.
* Repeat two more times.
* Start the engine. The SRS light should come on for seven seconds, and then shut off and stay off.
* Boom. The SRS system / light has been reset!!
