benhasavan
Hi all, I've adapted a wiring diagram (attached below) from the "far out ride" site to suit my 2005 Dodge T1n. This is the first electrical thing I've ever done, so total noob here. There's a few questions I have...
1. The Sterling 60A B2B charger instructions call for a common ground between the starter and house batteries. I ran a 2/0 negative wire 20 feet from the house negative buss, but the 2/0 lug is too bulky to connect directly to the negative post on my starter battery (unless some sort of adapter exists). Is it adequate to connect to the same ground point on the chassis that the starter connects to? Would that constitute a common ground?
2. I ran 2/0 based on the ABYC recommendation that "the grounding wire is able to carry the maximum current that the current-carrying conductor can supply." Thus I decided on 2/0 since the largest conductor elsewhere in my system are the 2/0 wires between the house battery, shunt, switch and buss bars. Is the 2/0 ground size adequate, given it's a long 20 ft return to the starter battery chassis connection? I.e. Should I be worried about voltage drop in regards to the ground connection? I'm not sure if I'm totally misunderstanding the ABYC guidelines.
3. Per the last question, I've seen people on the forum add a second ground between the negative buss and chassis closer to the house battery for "redundancy." Would that be a good idea in my case?
I thank anyone in advance for their help in saving me and my van from a catastrophic diy fail. Also I apologize if these questions are redundant. I've been lurking this forum for a couple years now and have always found an answer in someone else's thread, but I'm having a hard time finding a post with these exact questions.
Thanks,
Ben
Photo of where I'll be connecting the 2/0 negative from house buss (to what looks to me like the chassis ground from starter negative):
Thanks,
Ben
