I have an Espar D2 Heater with HAK that has been running flawlessly since it was installed over 18 months ago. A few days ago went to turn it on and the red light on the Easy Start came on like normal but just shut off again before the blower started. There are no error messages in the Heater or Control Unit Settings menu. Any ideas on what might be going on and how to troubleshoot would be appreciated.
I think the most likely reason (in my experience) for red light/no start just before blower is low supply voltage assuming heater has otherwise been running flawlessly. It may have enough to switch to "enabled" and start to start, but when it draws higher current to fire up, the voltage drops below the cutoff limit. It stops the startup process and lights up the red trouble light.
Use a multimeter to check the supply voltage, the closer to the main heater unit the better. Monitor changes while the heater tries to start. Compare with low voltage cutoff limit for heater. If voltage seems low, take action to increase voltage to nominal level (i.e., charge battery). When at nominal level, try starting heater again.
