Hi All,
Just back from an Easter trip with the 4x4 316 NCV truck. Really impressed with the driveability, not so much with fuel economy (14.5-15L/100), but that happens with a big wooden box on the back at 100km/hour I guess.
On the way back I went to start the truck. A short wheezy crank or few (no start) then I slipped off the key. I went to start again and the starter motor appeared to be no longer engaging. Nothing else wrong, just the starter spins (clearly heard) without engaging anything. I ended up getting a pull start (super easy, started like a dream) and drove home (no stopping...).
Just wondering if there are any insights on this particular problem? In particular - is it likely that I have broken all my ring gear teeth and need to replace that? Or is it likely to be an electrical gremlin along the lines of Eric's 'click, no-start' thread? It does seem to be a different set of issues to that common thread though - there is no click and the starter runs freely.
Overview:
Any hints greatly appreciated.
I'm in Adelaide BTW.
Cheers,
Daniel
Overview:
- Starting has been unconvincing at best since I got the truck mid last year despite replacing the starter motor and installing a new battery.
- Otherwise the truck drives very well (I don't really think fuel consumption is too bad given the 2m box on the back of the tray).
- Car almost started when I slipped off the key but was very wheezy - seems to take quite a bit longer than it should and seems to be making some wheezy/slipping noises
- Since then the starter has just spun completely freely. No warning lights or other issues have come up.
- Car is running perfectly from what I can tell.
Cheers,
Daniel
