sarl_cagan
2006 118" SHC in Portland, OR
Hello!
After a loooong search, I found a 2006 T1n cargo van and I'm in the process of cleaning it. One of the "features" in this van's previous life was a center console / "file cabinet" / "clip board". I'd like to remove it but I simply cannot figure out how it's attached to van. If anyone has experience installing, or removing a box like this, I'd love to learn how it's done.
I figured the box was aftermarket (like THIS)... but I cannot find any screw heads, or mounting flanges anywhere. Its just STUCK to the floor. The thought crossed my mind that somehow it was a "factory" upgrade... and therefore maybe more "integrated" in some way.
Theories:
A) it has welded on threaded studs that protrude from the bottom and go through holes in the floor. I'd suspect to find nuts somewhere beneath the van.
B) it was attached using a fatty sheet of VHB... and is simply "stuck" to the floor.
C) there is an imperceivable false bottom to the box.. under which I'd find some screw heads to unscrew and free the box.
Other food for thought:
FFT1: I did find some sheet metal screws protruding beneath the van. Does anyone else have these screws? (GREEN arrows in photo) Admittedly, I need to do some more reference/measurement making to see where the box should be when I'm beneath the van.
FFT2: The rubber floor does not want to move either. Maybe its really really stuck down itself... or its being sandwiched by the box and the floor.
FFT3: On the inside of the box, the only visible features on the floor of the box are two small holes towards the rear. No fasteners. (In the photo, there's a random loose screw in with the dirt and grime)
FFT4: The van had a Weatherguard partition... so I suppose in theory, maybe this box could be Weatherguard as well. I found THIS example (installation manual HERE)... but you can see that it is attached using bolts (to blind fasteners).
I was able to wedge some tire levers beneath the box with a hammer. I do not hear anything like unsticking adhesive... It is *really* difficult to wedge them in. This makes me think it actually is hard mounted... and I'm about to destroy something if I push forward.
Regards!
(edits - grammar, and added more food for thought)
Theories:
Regards!
