The Thetford hose is very flexible, but also a bit fragile due to thinner material (that keeps it flexible). Just be careful and not drag it across any rough rock or concrete... and at the end of the cycle for dumping, these tend to move around a lot and if on a rough surface it may wear a hole in the thin tubing. I can't comment on if it will fit or not, but you can get the Thetford end piece that goes into the dump station hole. Some of us have purchased a nylon weave sleeve for the hose. PITA to install, but it definitely protects it.
