Dear Members, i have problems with my sprintshift gearbox...
The gearbox jump out of A when i stop the car, then N flashes and F sing..
If i dont stop the car it works perfectly.
There is a low hydraulic pressure fault code. I checked it with diag, the pump builds pressure 50bar then it drops as gear changes. It goes below 30 bar..
There is a new clutch kit with dual mass flywheel, i have another car with same gearbox, i changed the pump, the accumualtor, the relay, but it still the same..
Door lock switch is okay as well.
Pump works for 5-8sec but it works with every shift..
Any ideas?! Thanks for your help
