VS30: Watch out for your diff if getting tyres changed
andyje
I took my 2019 sprinter in for new tyres this week, and after I got home I had a new oil patch on the drive where the diff was leaking oil.
It was pretty obvious the tyre place had jacked up the back of the van by the diff, and bent the rear cover plate.
It's a fairly thin pressed thing, and it slightly protrudes below the level of the diff body itself.
They took care of the replacement, but at the sprinter dealer, the service team told me it's common damage. Pics to show:
dddrks
Yikes. I’m due for a tire rotation and stories like this motivate me to do it myself vs. saving time and taking into the local tire shop.
jjmcclure
2020 HR 144 4x4
Thanks for the heads up. I am too paranoid to take my car to the big shops, have not rotated the Van tires yet, but I think I will...
andyje
Me too, Jim - it feels as though every time my bike or van is in the garage, it picks up damage from clumsy mechanical work or damage.
In a slightly related note, I found Van Compass and Owl Vans here in the US make a bash guard for it... it's pretty exposed. The lip is certainly proud enough to do pick up damage from rocks if you venture off road a bit.
220629
andyje.
The cover is not bigger than the housing, the problem is jacks have a flange that protrudes above the main lift plate. Of cause the problem is mechanics do not read instructions. I Make a protector for diffs but I am in Australia. Eric.
The particular damage in the picture does look like one of the jack cup ears caught the flange, but I agree that the cover design could have been less proud aka more recessed to the differential casting. Although the cover is level with the bottom casting, so the real problem is the jack cup ears catching the cover as Eric Experience mentioned.
The T1N diff cover is similar. Commencing 2008 I have been using various floor jacks to lift using the differential. Most often I use a chunk of plywood as a pad, but I have also used a hardwood block. A suitably long hardwood block can catch both the round casing cover area and the differential body, but I don't make that SOP.
Added:
A VS30 video that I found.
After the 2:20 mark this video will show where the Mercedes dealership hoist contacts the frames for lifting. If you know vehicles you will be able to identify a number of spots where a padded cup of a floor jack can safely contact various places for lifting.
You will find many old T1N threads on the pro's and con's of lifting the Sprinter by the differential "pumpkin"
The books, of course, all say "DON'T!!"
220629
Since you brought it up.
What books?
Maybe all say "DON'T" when using the OEM tire change jack. [All operator manuals anyway.]
For those who might be interested, there is some discussion for the T1N Sprinter is here. Post #75.
The "Thou Shalt Not Jack a Sprinter Differential" Myth
https://sprinter-source.com/forums/index.php?threads/3301/page-4#post-90965
Added:
Many have also interpreted that the front cross member shouldn't be used for lifting. (NOT the transmission support. Don't use that.)
This T1N Daimler "book" specifically says to use the front cross member for lifting.
There is written documentation that Mercedes Benz includes jacking the front end of a Sprinter by using the cross member as I have suggested and pictured in many of my posts. The reference is not Sprinter 2500 or 3500 model specific.
From the Supporting ball joint check PDF
Issued:
01-22-2010 8:46 PM © Copyright Daimler AG PID24C5
Ball Joint GI33.00-N-039932_Ver_3.pdf
(Attached. View bottom of Page #1)
Quote:
Checking for wear:
Raise the vehicle at the front axle at the center of the crossmember at the level of the leaf spring using a pit lift until the wheels are no longer in contact with the ground.
Of course when using a floor jack a wood block or other bridging method to bear against both flanges of the cross member must be used. Otherwise it is possible to bend or distort the individual cross member flanges by lifting against just one flange. (See the pictures for the bridge block in Post #1 above.)
It's a shame that so many Sprinter owners seem to have become convinced that the lift points provided for the included factory 2 stage hydraulic tire changing jack are the only safe places to use when lifting a Sprinter. There are so many other completely safe options than those tire change lift points (which are almost inaccessible unless using specifically designed jacks).
The PDF for the above text is attached.
Some Sprinter owners interpret the jacking/lifting cautions differently than I do.
  • Ball Joint GI33.00-N-039932_Ver_3.pdf
andyje
Perhaps another picture to demonstrate what I mean by the plate being proud of the body of the diff. I did not say it was bigger, I said it slightly protrudes.
This photo is taken with the camera parallel to the ground and you can see the plate flange/lip is the lowest point. Of course I’m not advocating for careless jack work, but just to give a perspective on the vulnerable position of the plate.
65C02
404
A tire place that screws up changing tires is like the oil change place that screws up changing oil.
Lucky they did not use a bottle jack on your uni-body frame rails or bumper cover.
So what changed between the above referenced pumkin lift thread from 2010 and the following 2017 thread ?
Wrinkledpants
2017 144WB 4x4
It’s why I only go to dealers for work. Our local MB dealer is $120 for oil changes, $90 to mount tires, and $40 to cross rotate. Plus, I get a nice place to work while this happens. I know it everyone lives next to a dealer, but I’ll never take the van to a quick-anything place.
220629
Nothing in my opinion.
I saw no pictures of the actual damage to the cover in that thread. What likely happened was that an ear on a floor jack cup caught the cover and bent/distorted it. That is a known failure. Nobody I have seen argues that point. The remedy is to not use a bare floor jack cup that leaves the ears and cup rim sticking up. A padded jack cup as described in the many other threads avoids the problem.
Those that don't feel comfortable with jacking their Sprinters using the differential for lifting shouldn't use that common and convenient method. I have yet for anyone to produce an official Mercedes document that cautions against lifting using the differential other than sections related to the OEM tire change jack. To date nobody has provided a documented differential jacking related example of the axle tube socket assemblies failure where they attach to the differential.
Be careful with the frame when jacking your Sprinter though. :dripsarcasm: :dripsarcasm:
