I'm looking at taking my interior back to the drawing board and reclaiming the space that I had set aside for water. I think I can mount the hot water tank on the driver side and am trying to figure out if I can reasonably add a freshwater tank to the passenger side. From my measurements, I can really only get something 6.5"x9"x57" in there and am not seeing any commercial tanks with anywhere close to those dimensions. Even optimistically assuming that I could take up that entire space with zero wall thickness, that's still only a little over 14 gallons. More realistic is probably 13. Is this worth it?
I did read up on @GeorgeRa's build including the recommendation of internal baffles, but having never done a build of a water tank at all, I don't know reasonable fittings for fill, output, vent, monitoring, (heating to prevent freezing?) and would appreciate pointers if anyone has experience.
@GeorgeRa Do you have higher resolution images of your design? I tried enlarging them but the text was mangled.
Thanks in advance, any and all, for info on this.
Fresh Water Tank under the chassis Questions
Looking at putting a 8"X 11"x 48" 16 gallon fresh water tank under the chassis on the driver's side on a NCV3 Sprinter 144, (right behind the drivers seat). This would be directly under my stove/sink/ref cabinet. The water fill access positioned on the counter top (stainless marine style deck...
sprinter-source.com
Layout plan.
Very nice design work. You make us all look like beginners. FYI my 7 night trip to NW Sprinterfest was done without any charging other than the 135 watt 17.7 volt Kyocera solar panel. Lowest SOC was 88%. Weather was combination of sunny days and overcast days. On my way back home I stopped...
sprinter-source.com
