I've ordered some riv nuts of that size, thanks.#10-32 pre-bulbed plus nut hole size is 8mm.
plusnut size chart
Just found this thread and I'm wondering how those 10-32 Rivet nuts worked for your Sprinter. I see they're available from McMaster-Carr. Did you order the 0.020-0.130 material thickness? How have they weathered the test of time? TIA for your thoughts.I've ordered some riv nuts of that size, thanks.
Do you have a suggestion for where to buy plus nuts for a reasonable price? I was planning on using plus nuts for the more substantial loads but they seem very expensive.
Mine is a 2023 Crew Van. I'm confused. If I go with metric sizes, and I should since the whole van is metric, the inside diameter of the hole is 8.0 mm, so what size in metric drill bit and plus nut/and/or/rivet nut should I use? TIAFor fitting into many of the T1N Sprinter's holes, i found Plus Nuts as being far more forgiving of "loose" fits.
I am exceedingly agnostic about "metric" versus "Imperial" when it comes to what i use for "converting" my Sprinter.Mine is a 2023 Crew Van. I'm confused. If I go with metric sizes, and I should since the whole van is metric
Let's see ... 8mm is 0.31496 inches ( just over 5/16ths of an inch (5.0394) ((and well below 41/128ths)), the inside diameter of the hole is 8.0 mm, so what size in metric drill bit and plus nut/and/or/rivet nut should I use? TIA
I live near a United Fastener shop and they have metric bolts, too. I brought my van to them because they've helped me before and they have a super nice caliper to help me out and measure for me. Bear with me, as I'm trying to grasp the #s here. In general, you're saying the Plusnuts are a better fit because they are far better at being forgiving for "loose fits" and do NOT require a precision hole. The M5 X 0.8 plusnut is shy by 8.0 mm by 0.53while the 10/32 is shy of the 8 mmm by 0.037. Wouldn't the 10/32 be the better fit?(@ECU and i were tippy-tapping at the same time)
Here in the US (you are doing a Dodge), Imperial fittings are far easier to find thanwastingspending time seeking metric.
(certainly if i'm using a threaded stud or fixed nut supplied by MB, i go metric)
As you're finding out, that falls into a definite gap in the PlusNut catalog (metric or Imperial)
The 10-32 PlusNut has a body diameter of 0.272 inches, and fits a hole spanning 0.273 to 0.278 inches. (shy of 8mm by 0.037 inch)
The next size up is 1/4-20 (which i used): body diameter 0.346 inches, hole from 0.347 to 0.352 inches.
The metric PlusNuts have a similar gap:
M5x0.8 has a body diameter of 7.48mm, for a hole size of 7.62 to 7.47 mm (shy by 0.53 mm : 0.021 inch)
and the
M6x1.0 has a diameter of 8.80mm suitable for a hole size of 8.93 to 8.79 mm
So for the closest (loose) fit, the M5 x 0.8 PlusNut comes the closest. 0.53 mm undersized instead of the 10-32 0.9 mm undersized.
Despite the PlusNut's *specifications* being too small for an 8mm hole, the width of the "squashed" retention metal would still work in that hole.
Unlike the RivNuts, they do NOT require a "precision" hole for their grip. They do not have "teeth" to engage the edge of the metal.
(the one on the left is a real PlusNut, the one on the right is a knock-off)
PlusNuts handle loose tolerances very well.
Are you saying the depth isn't enough to support a lot of weight? Seems to me there's a good bit of space behind those 8mm holes.One of the issues is finding the right size that fits the hole. Then the bolt that fits that thread are going to be smaller.
I went with 1/4 x20 threads since this is used in furniture and there are lots of choices for screws, bolts and such.
That is an M6 in metric.
It required drilling.
Your request is :
M5X0.8 ISO 3.30 - 5.70 7.60-7.75 7.520 0.480 8.640 14.86 8.00 BRKS-580-5.7
The thread is a M5. This might not work as it is 3 to 5.7 mm depth.
To (mis-) quote Yoda: "Ahh... Lucky you are"I live near a United Fastener shop and they have metric bolts, too. I brought my van to them because they've helped me before and they have a super nice caliper to help me out and measure for me.
Yes, it's confusing (i recalculated the "0.9" twice).Bear with me, as I'm trying to grasp the #s here. In general, you're saying the Plusnuts are a better fit because they are far better at being forgiving for "loose fits" and do NOT require a precision hole. The M5 X 0.8 plusnut is shy by 8.0 mm by 0.53while the 10/32 is shy of the 8 mmm by 0.037. Wouldn't the 10/32 be the better fit?
"So for the closest (loose) fit, the M5 x 0.8 PlusNut comes the closest. 0.53 mm undersized instead of the 10-32 0.9 mm undersized." Is the 0.9 a typo or the 0.037 further up in your explanation. I appreciate the explanation. I'm trying to understand all the nuances of reading the chart sizes posted.
