The Craftsman sockets arrived early this afternoon - absolute crap, nothing like the picture on Amazon, which looked like MWG's craftsman sockets - they are going back. Much later the Snap-On E12 only sockets I ordered arrived. OMG what a difference. MWG - the socket was a fraction off being flush with the flange on the bolt. Used the universal joint socket attached to a 24" 3/8" extension, with another 9" 3/8" extension, a 3/8" to 1/2" adapter and then a 1/2" breaker bar 17" long. I did not attempt to use my custom breaker bar because over the weekend while crawling under van to do the daily soaking with PB I realized that I had almost a straight shot at the 2 bolts from behind the transmission, and the universal joint socket was the trick needed to get the socket sit squarely on the bolt. Attempted the one that was least damaged on the top from my original attempts to remove them. With the length of the extension bars the breaker bar was twisting them. I did this several times and would hold the tension as long as I could. The last time I did it something snapped and I was off the bolt with the socket. I assume I had let it slip off, but when repositioning the socket on the bolt I realized it was loose and I took it out with my hand turning the extensions. Next bolt had a little rounding, but the socket went over it snuggly and I proceeded to break it loose. I am a believer in the quality of Snap-On tools now, and will be buying more!! So the turbo charger is finally out. In looking at the collateral damage from cutting one bolt off the Y exhaust collector I see that I cut right through the cast iron, so the Y collector needs to be replaced. This will not happen again with my Snap-On tool kit!! Took the EGR cooler off this morning and am now figuring out the vagueness of the WIS instructions for removing the mixing chamber. Getting my order in for all the parts I need tomorrow so I can start replacing this wiring harness and get this van back on the road.
