I installed my Espar heater in the passenger seat base like a lot of people do. The one issue with this install that I do not like is the termination of the exhaust pipe. With the limit of 1.3 meters of the 24mm exhaust pipe, it does not make for a lot of options. Most installs I have seen, the exhaust pipe is either terminated under the passenger door or the slider door. Neither of these options appealed to me. Initially, I wanted to run the exhaust to the driver side but the fuel tank on that side and my future plans of installing a larger fuel tank did not make that a good option. So, the best I could come up with was to extend the exhaust pipe down the passenger side. With the longer exhaust pipe I decided to increase the exhaust piping to 30mm diameter so I don't increase the back pressure on the heater unit. Through my research I have read that longer then 1.3 meters of 24mm exhaust pipe will create more carbon build up which leads to more maintenance and if the back pressure is to great then the unit will not run. The extended exhaust pipe is built from: 24mm exhaust pipe coming off of the heater unit to 3/4" to 1" copper adapter, 1" copper union, 5' section of 1" copper pipe to 30mm exhaust pipe to 30mm exhaust muffler and then back to 30mm exhaust pipe with 30mm end cap. Copper parts were purchased at Home Depot and Espar parts are from Esparparts.com. The 24mm exhaust pipe does need to be stretched out very slightly so the 3/4" to 1" copper adapter fits inside the 24mm exhaust pipe. Adapter, union and copper pipe were soldered together. Ran the heater for a half hour, seems to run well without any issues.
