What engine...
Correct me if I'm wrong but I thought 4x4 was only offered with the 3.0 litre V6 Diesel engine.Am looking at buying a 2017 NCV3 2500 4x4...
That is what I was afraid about.Correct me if I'm wrong but I thought 4x4 was only offered with the 3.0 litre V6 Diesel engine.
Drive it in 4x4 and make sure there are not any noises not present in 2wd.Am looking at buying a 2017 NCV3 2500 4x4 with roof mounted AC people carrier. What should I be aware of on testing the 4x4 system for proper function? Any thoughts about replacing some of the windows with MBZ sheet metal replacement panels as well as the barn door windows.
Run the VIN through one of the free VIN checker websites, such as http://mbepc.net/f/vin/ or https://www.lastvin.com/ and look at the build options listed.Mileage is about 70k. How does one observe visually (something on the dash or shifter) if the vehicle has both a high range and low range xfer case?
There is lot about it on the net, so in shortMileage is about 70k. How does one observe visually (something on the dash or shifter) if the vehicle has both a high range and low range xfer case?
@Kajtek1 - can you elaborate on "oil cooler seals and intake gunk"? I can only imagine what this vehicle would cost new.
Thanx
Good van, good option, but lets get you a 2022 order so that you can save moneyThat is what I was afraid about.
V6 has couple of expensive maintenance items like oil cooler seals and intake gunk.
Still nice vehicle otherwise.
Are you guaranteed the next latest and greatest won't be the same & not cost free to run????Good van, good option, but lets get you a 2022 order so that you can save money
I love my 2017. Since it's a passenger van I had "ALL" the bells and whistles. When I first got it I thought I wouldn't use half of it, but I use all of it. Even the roof A/C during the summer. I've often thought about getting rid of it. I could add a roof mount, with cool roof box, big ole lights, and a bunch of other gas sucking wind blocks and have my mileage go to crap with a lot of noise. But I haven't done that yet. Is the one you're looking at a stock van or finished out? Really depends what it's got on it and if the PO's new how to take care of it.Am looking at buying a 2017 NCV3 2500 4x4 with roof mounted AC people carrier. What should I be aware of on testing the 4x4 system for proper function? Any thoughts about replacing some of the windows with MBZ sheet metal replacement panels as well as the barn door windows.
