Victron Remote Monitoring
Peter Tourin
I finally got to taking a peek at this. Do you know yet what it costs and what the data will cost, if I manage to live another 5 years at this pace <g>... It would be nice to be able to watch the electrical system at a distance, since we store for months at a time.
DiverBob
2018 Unity TB
This appears to be another option for remote monitoring. If you have the Cerbo, Venus, or Color Controller you use the local WiFi networks to access remote monitoring. This gives the option to use cellular networks instead of WiFi (don’t know if it also includes WiFi as an option). Could be a good option especially if you store in a location that WiFi isn’t available.
hoosierrun
I wonder if the short range Bluetooth connectivity will still work? There are so many places I go or store my rig where there is no cell service. In those remote boondock/parking areas, it is critical to be able to monitor your systems.
msmolow
2019 Unity CB / 2018 Chas
$343 USD includes 5 years of connectivity. It uploads on a fixed time schedule.
From my cursory reading it cables to and uploads direct from the bmk and mppt, not from the Cerbo.
I'm not sure if the bmk and mppt have enough ports to plug in both a Cerbo and a Globallink-520.
TampaSteve
2018/2019 Unity CB
I have permanent "house Internet" through a router in my van, and remote connectivity to my Victron BM and solar charge controller through the Venus, so the new Globallink is designed for someone who doesn't have or want a router or hotspot. It certainly should be a lot less expensive - an AT&T LTE-M/IoT subscription is only $30 a year currently for one device, so even after your 5 years are up you should be able to keep connected relatively cheaply. They may have dumbed it down with less uploads to keep on an even cheaper plan - which is $1 a month for a single megabyte.
The main disadvantage I see is that with my router I have more diversity - both Verizon and AT&T sims - and can also set the router to sip off a WiFi for those rare occasions its present. With the Globalink there are going to be a lot more situations where there is no connectivity.
The other important distinction is that with my Venus I get full remote control - not just monitoring. I can even run the full color display on my phone. I suspect Globallink won't do that as it would be way too much bandwidth for the cheap IoT plans.
Of course I have to pay steep monthly fees for carrier sims with a router, and even with 2 sims there are still plenty of dead zones in remote areas.
Edit: Here is a screenshot of the remote color display from my phone:
Git
@TampaSteve what router are you using? What router would you recommend for AT&T LTE-M/Iot? Just looking to connect to Cerbo remotely.
TampaSteve
2018/2019 Unity CB
@Git I'm using a high end peplink router mainly for video streaming so you almost certainly don't want that just to monitor cerbo. Unfortunately I don't think anybody sells a general iot router yet. You would have to get a sim with a monthly plan, and a low end hotspot at a minimum. It would probably be worth looking at the Victron globalink I would think.
  • Thanks
Reactions: Git
msmolow
My storage lot is in a neighborhood. Some of the homes have Comcast. By default Comcast has their boxes act as a hotspot to other Comcast subscribers.
I connect the Cerbo to the Winegard which is connected to one of the hotspots.
The Winegard amperage draw is minimal, easily maintained with solar.
  • Thanks
Reactions: Git
cbaarch
2016 Unity MB
so after 5 yrs do you have a brick if you do not renew your connectivity contract?
TampaSteve
2018/2019 Unity CB
Presumably, but at $343 for 5 years it will have been a very economical brick indeed. About $5 a month there aren't going to be any sim hotspot plans at that rate. My guess is the renewal will come in much cheaper so I think its a great deal for someone who wants full time monitoring (well full time when you have a cell signal anyway) and doesn't have a router or hotspot in the RV (or nearby wiFi, like Mitch).
