Law2500
2002 Freightliner 158"
Hi everyone I have been doing all the service work on my recently purchased 2002 T1N 2500 LB-HT (FedEx owned 481000 miles) and I was wondering if I should service the transmission. The trans looks as if it has been replaced, the fluid is rose red with a pink ish tint when you wipe the stick on a clean towel, the bolts that hold the trans to the engine show marks of removal and mounts show no cracks in them. I read a tread in the database that advice you not to remove and clean the valve body with you are not getting any trans codes and I am not getting any when I scan the trans nor am I getting any check engine light, but the issue I am have is,,,the trans shits from 1fst to 2nd too soon and its a firm shift, it does it ever time the van is driven.
Would a slightly smaller tire cause this issue, the van came with 4 brand new Yokahoma Geolander G015, 215/75R15 6 ply tires on it.
Thanks Amous
Thanks Amous
