Trailmater!
BINGO.Trailmater!
Now that's beauty and the beast all in one package!!!!!!!!!3500 Dually 4x4 170 Extended
Curious what mpg you avg. with this OM642 rig?3500 Dually 4x4 170 Extended
Which one is the A/C that you have in the front? I got the RecPro low profile, that I guess looks like yours, and I want to put it all the way in the front and I was scared that will get out a little bit on the frontView attachment 233227
Sedona, AZ
Nice. How much solar is that?
520W total on the roof, all Renogy. Central deck area is Trex over top of a Fresair evaporative unit. Over top of Trex is Renogy flex panels so I can walk on them to access the Pelican cases and sip a drink at sunset!Nice. How much solar is that?
The white one is RecPro 13.5 k BTU. It was forced location due to other stuff I had on the roof, but I wish I could put it at least 4 ft to the rear.Which one is the A/C that you have in the front? I got the RecPro low profile, that I guess looks like yours, and I want to put it all the way in the front and I was scared that will get out a little bit on the front
Exactly the one I got cold/heat 13.5 And I was planning to install it all the way to the front. Since I want the max space that I get for solar between the A/C and the vent on the back. But now, I'm thinking may be I can put a solar panel at the beginning and then move the A/C two rows back.The white one is RecPro 13.5 k BTU. It was forced location due to other stuff I had on the roof, but I wish I could put it at least 4 ft to the rear.
Thanks for the pictures! Do you remember the model of the small renology panels that you added on the side of the vents?520W total on the roof, all Renogy. Central deck area is Trex over top of a Fresair evaporative unit. Over top of Trex is Renogy flex panels so I can walk on them to access the Pelican cases and sip a drink at sunset!
Additional 320W of portable solar in form of 2x 160W EcoFlow panels. These are nice and slim for easy stowage when moving.
Supports a 400Ah Renogy LifePO4 bank in a custom floor box I made (inspired by VanCompass’ product but wanted it bigger since I’m working with a 170EXT). Photos below show the box mid-build. Hides away nicely in the central hallway and left plenty of storage space under the bench seats.
