Hi Kelly, thank you for sharing your project knowledge.Easy: simply run the new panels over the old ones. You will find that you can screw the new mounting brackets to one side of the existing panel and the other side through the existing panel and into the roof. You can also build a foot using those brackets and stick them to the roof using VHB (very high bond tape). When upgraded my Unity to Renogy I ran them over the top and did not worry about putting new screw holes in the roof. Use the existing cables to connect.
You're going to get a ton of help on batteries and all other stuff but to keep it simple stay on your path of simplicity! If/when you start to wander off that path? Oh my!
Here's a photo of the bracket I built. 3/8" aluminum and stainless steel hardware:
We have a 2022 Unity RL on order and are planning to do the solar install ourselves.
I have some questions regarding the foot mount for solar panel mounting bracket you fabricated.
I see the thickness is 3/8”, what are the other dimensions, length and width?
Also how did you attached the bolts to foot mount?
Are your mounts holding up?
Are there changes you would make?
Thanks again for sharing your project knowledge.
Tom
