It's been a long project . Bought this van back in may 2020 with a cracked piston. Now after installing a good short block ,new oil pump , cam chain , water pump , head , 5 new injectors, overhauling turbo , installed an om647 intake manifold . Also added a low pressure lift pump before the fuel filter.
I can only get it to run 1 second and it stops
No fuel pressure.
Found 2 connectors that are not hooked up to anything. One's back near the starter ,has one wire ,(not the crank sensor, its connected) .
The other is up top on the head and is a 2 pin female connector. (Not the cam sensor)
I'm in Vancouver BC and dont know anyone who has a 2002-3 sprinter to compare with . . It's been 9 months since I took it apart . Any help would be appreciated
No fuel pressure.
