spagthorpe
I looked on here a bit at ball joint problems, and saw a lot of mention about tire wear on the inside edges. I have the opposite thing going on. I hadn't noticed it till a friend mentioned that I needed to check my alignment. The outer edges on BOTH tires was bald.
As a temp fix, I swapped the tires from side to side so that the outsides are on fresh tread, but it's obvious I have to replace the tires. I just would like to fix the problem so that the new all too expensive tires will at least last a while.... The tread on the current fronts is great...sucks to have to replace them early.
So can ball joints do this the other way?
