As some of you guys know, adding auxiliary (extra) high beams isn’t possible when your Sprinter is fitted with LED headlights (due to being CANBUS controlled, no separate signal wire to high beam) and without PSM (Specialized module, rare to have, $$$). But there is another way! It’s called the “CanM8 Cannect High beam”.
It’s a small device that connects to a constant 12v power source, ground, CANBUS Hi and CANBUS Lo. Coming from the device is an output of 12v with 1A max for switching on a relay. With this device installed you can have LED Headlights and auxiliary (extra) high beams. The dealer quoted over €600 for the PSM alone. This CanM8 Cannect was around €80. Just wanted to leave this here for the people that have the same problem. Wanting to add auxiliary high beams but don’t know how.
