@alex.southpole As I understand it, the Loctite gel is used as coating to prevent galling on the stainless steel screws that attach the L track to the steel framework and speed struts. It won't actually lock the screws into place because you're going to be tightening and loosening the screws several times during the install and so breaking the bond. If you've ever worked with stainless fasteners, you know that galling is a horrendous problem. So make darn sure you hit every screw with a glob of the gel.
The use of stainless screws is something new for AdWag. They used to use regular plated screws which didn't need Loctite. However they developed corrosion over time due to condensation. So not everyone will have used the Loctite on their installation depending on which screws they got.
I had many screws loosen soon after my install. However, since going back and snugging every screw, they've held perfectly now. I think a lot of it is just having things settle into place.
I'm still pretty bullish on AdWag. It's quite awesome stuff and suits my intended build perfectly.
