hilld
I am making my own AdVan kit, almost. I did buy the V2 bed install kit, so I have the vertical rails. I am installing the horizontal L-Track using Plus-Nut, so hopefully they won't be pulling out. Also I am using US Cargo Control L-Track, where there is a screw hole every 4".I’m not totally happy with my kit. I wished I had a better phone conversation over the phone what is included that varies from photos on the Website. Somethings are very well done. Some areas are lacking.
The rear doors without windows should include fabric panels or extra fabric to complete at home.
The back side panels near rear doors that run from floor to ceiling. If you opt to have your bottom panels none fabric then the long panel should also match the bottom portion of the other panels. This drives me crazy because I store gasoline and toolbox here. I’m ordering hexagon to cover fabric in this area. “Photos included
I’d suggest drilling added holes in orange frame for more rivets. You are securing a L track with the rivnuts. That doesn’t sound smart. If you have anything mounted to the L-track that will shift while driving this will pull the l-track/rivnuts from the body. Mine lasted about two minutes on a dirt road. Not a very good Gear Hauler.
Adding a light switch is a must for celling panels.
Maybe I’m just bitching.
Basically, the question I am getting at, what did you use after you pulled out some of the RivNuts that failed on you?
