danielmccoy
2004 Sprinter Westfalia
Yesterday I attempted to open my skylight to adjust the antenna on the roof. As the skylight was attempting to open, in sub-freezing temperatures, a grinding and crackling noise started to come from the left side. The skylight did not open completely. I immediately stopped it and tried to lower it. That did not work either. It was stuck 1/4 open. Freaking out, I attempted to figure out what was wrong. Eventually (after taking the four plastic pins out of the hinges on the exterior) I discovered that the left driveshaft had come unwound. The driveshaft is a steel cable inside a plastic sheath (see photo). I am assuming that the skylight might have been partly frozen to the seals, causing extra resistance. Luckily, I had spare driveshafts that I recently acquired (otherwise it would have cost £92.88 from Leisure Parts Direct). The driveshaft is easy to replace, it just slips on both the gearbox and the mechanical lift (grey box).
I would urge you all to do routine maintenance on the Heki 4, including:
- Vacuum out all the bugs that inevitably die up there.
- Spray silicone or PTFE-based spray on all the hinges and the mechanical lift (the grey boxes that contain the screw-type mechanism). After doing this, the skylight went up noticeably quieter. Try and apply some of this inside the driveshaft (where the plastic sheathing and the metal ends join).
- Apply 303 Aerospace protectant or Armour All to the gaskets for their protection.
