Tranny test
Sunny&75
Is it possible to run the transmission without driving? I have this harmonic noise around 2000rpm, and would like to identify it using jack stands? Thanks.
Bobnoxious
For a few dollars more
Very dangerous.
Mercedes has already concluded this normal resonance.
Bobnoxious
Thanks for the non answer?
All my pleasure and you certainly won't receive anymore.
Oh, and there's another for 4x4's but get your mech to find it.
Bobnoxious
Oh, and there's another specific for 4x4's.
Mike DZ
2016 View 24V (2015 3500)
Actually the best method is achieved by using a set of chassis ears .
That's what we use !
Absolutely true, as it allows all of the components of the vehicle to be loaded and operate normally.
However, when my local dealer tried to locate my drone (after replacing the rear axle), with chassis ears they could not localize it even after multiple tries. The techs that came MBUSA HQ stated that the vibration was inherent to the 3.0 ltr engine design, transmitted down the driveline and is expressed in the rear axle. They referenced a notice like the one that Bob posted, even though my drone is most intense around 2000 and 2800 rpm
Kajtek1
2015 3500 X long limo RV
Sprinter vans have either ESP or ASR traction system, who will kill the engine control when wheels speeds don't match.
If you want to run rear axle in the air - you need to turn the system off.
That's is what I always do going for smog check, who puts rear axle on the rolls.
