In our 2016 Ascent, we have a Girard Model: GSWH-2 on demand water heater.
We have owned the camper for 2 months now and initially the water heater would work fine and heat the water to 124 degrees (setting we had). Recently, when you turn on the heater and turn on the hot faucet, the water temperature starts at about 60 degrees and then slowly increases up to just over 100 degrees, but it will not go much higher.
A week or so ago, I turned on the water heater by mistake with the propane off. I received the error code E1. Once I turned the propane on and fired up the water heater it seemed to work fine, but I did not test how hot the water got.
2 questions:
1. Any idea what the control button is above the red on/off switch? It is labeled c/f.
2. Any idea what we can do to get the water to heat up to 124 degrees as before?
Thank you!
Ian
2 questions:
Thank you!
Ian
