D
Deleted member 50714
Guest
Adblue High Input-Output latency?
Adblue related DTC's, CEL, Adblue low-level warning and No Start Countdown Messages.
I suspect many Adblue tanks are being replaced due to "defective" fluid level sensor.
What's to fail? ultrasonic sensor, has no moving parts to foul and electronics well incapsulated?
The heating element as well, appears stout.
IMHO, this may be a misdiagnosis due to accumulated System latency.
ECU is a cognitively challenged, dithering dunderhead.
Fortunately, performance improving firmware is always in the pike and available over DoIP (Diagnostics over Internet Protocol). In the future, this may become mandatory and done without your knowledge without your but with implied consent upon purchase agreement.
Moving on, Automotive emissions data is subordinate to and competes with engine operation data processing for limited, and apparently anemic processing resources.
To drive down cost, I am quite confident engineers calculated processor speed down to the nanobyte and provided not a nanabit to spare.
As a result, takes time for ECU to query and process the dozens of sensors and mountain of data.
For example, when the DEF low-level warning displays and DEF tank subsequently replenished, insufficient surface reflective area exists for accurate ultrasonic sensor function.
Only after DEF consumption reduces tank level sufficiently to expose the necessary reflective surface for accurate ultrasonic function, can the sensor begin relaying plausible data to ECU.
Lag duration depends on engine operation and importance of a drive-cycle profile that includes highway driving to accelerate DEF consumption.
All of this takes time for OBDII to sort out, and if all emission sub-systems are A okay, the CEL should extinguish with 3-Driving cycles.
Clear codes, perform drive cycle, save money.
Suggested Drive cycle
Driving Profile based on manufacturer's information.
Prerequisites
Clear codes.
Plan highway route.
Start with Engine cold.
Note: CEL may return. However, absent discernible performance degradation, continue the drive cycle.
1. Insert key in ignition DO NOT TURN KEY! wait 1 minute. (I understand this wakes-up Can Bus and possibly other electronics. I have no clue).
2. Turn key to position 2 and WAIT 30-45, and notice ESP systems booting on Multi-function Display. I saw a Mercedes Rep do this while demonstrating EPS and mentioned waiting for a bit for system to boot (30-45 seconds is my recommendation).
3. Start engine, idle not less then 30 and not more than one minute.
4. Perform drive cycle punctuated by three, 15-minute power downs. Each 15-minute Power down allows the system to do it emission drama. Remember, the vehicle has its own diagnostic system called, OBDII On Board Diagnostics, be patient, let it do it thing.
Now, the dealership has a machine that will do this but they're going to give you a Wallet flushing pile of hooey either as a result of the liberation or incompetence. Either way it's a 50-50 crapshoot.
If this works, donate to a "No Kill Shelter." And, I score the prestigious and most coveted Ablue Merit Badge and Adblue Hall of Fame inductee.
If not, don't call me a failure for trying.
Please share results?
Prerequisites
Clear codes.
Plan highway route.
