cbaarch
2016 Unity MB
We recently bought a 2016 MB - the water pump does not have a strainer. Trying to figure out if that was normal for that year.
Only reason this has come up is that I am experiencing hammering and looked at the setup so wondering if I should add one when I work on the system.
I went to our local hardware store to look for fittings; the salesman who owns an RV said all he did was T off a 24" PEX pipe and capped it.
I will be trying that first as that is the cheapest and the same fittings can work to replace the PEX with a water head arrester like found on hot water tanks in my house.
If that still does not work I will look at the Shurflo accumulator tank as suggested.
The accumulator is the most expensive option when buying in Canada so the other solutions are worth a try.
