SeattleNewbie
2013 NCV3 2500 170" WB
After a year of running our Espar Airtronic S2 D2L uneventfully, it has suddenly stopped turning on.
Neither the fan mode nor the heat mode work. The Easy Start Pro controller shows these error messages under Diagnostics > "Control Unit"
1. Int. temp sensor defective
2. No Heater
3. MISMATCH
and no error messages under Diagnostics > "Heater"
Has anyone had a similar experience?
My first thought (and the suggestion from the local Espar repair shop) is to try installing an external temperature sensor (~$100) to see if that helps.
I've pulled the electric fuse and reset the system already with no noticable changes.
Thanks for any tips or suggestions!
2. No Heater
3. MISMATCH
