Raymond Brown
Differences in 2017 314 and 316 is it same engine and different mapping or do they have some physical difference ie bigger turbo ?
Is this a different method that Green Diesel Engineering?... I am looking for anything to make mine drive better and have more power. I know GDE got put through the wringer by the EPA, what should I know if I am located in California?I mean, you can get even more with an actual tune on any of them
RENNtech Sprinter Van ECU Upgrade 2007-2023
Cut up to 4 seconds off your 0-60! **The ECU upgrade is NOT currently compatible with the 2024 Sprinters or AWD Sprinters** On our shop 170wb 4x4 with 265/75-16 and full buildout, testing showed a 17.95 0-60 (via obd2 app) before the RENNtech tune After the tune, we saw a 14.0 second flat. This...store.freedomvango.com
Saw 75 ftlb on my van
This one isnt a delete, just a tune.Is this a different method that Green Diesel Engineering?... I am looking for anything to make mine drive better and have more power. I know GDE got put through the wringer by the EPA, what should I know if I am located in California?
Grant, I saw you had those.This one isnt a delete, just a tune.
It has the option to revert to OEM tune within minutes for any reason you may need.
How ?I mean, you can get even more with an actual tune on any of them
I believe there was a video of Grant getting it dyno'd on FB.Saw 75 ftlb on my van
How did you see it?
User installed. I encode the dongle and send it out to you!Grant, I saw you had those.
Are they installed only by you or another RENNtech dealer? Or is it something that can be user installed, removed...like the old SuperChips tuners.
BingoI believe there was a video of Grant getting it dyno'd on FB.
I went to the dyno at Renntech and did it!Saw 75 ftlb on my van
How did you see it?
Does this work in conjunction with an app?User installed. I encode the dongle and send it out to you!
It does notDoes this work in conjunction with an app?
In reference to what?You can report suspected violations of the Clean Air Act here:
Nothing really. The only limiting factor is the turbo. Larger turbo and we can do more. We are working on a 450ft lb tq to the wheels tune with a larger turbo next. The engine itself has TONS to give. bottle neck is in other places. This is a relatively conservative tune.If it will be reliable this will be real good
400 lb ft with maybe upper 200 bhp?Nice
What are the downsides?
That is another animal altogether.Surely void your warranty etcNothing really. The only limiting factor is the turbo. Larger turbo and we can do more. We are working on a 450ft lb tq to the wheels tune with a larger turbo next. The engine itself has TONS to give. bottle neck is in other places. This is a relatively conservative tune.
