My 2020 UMB came without factory solar panels, and I found 8 AWG solar prewire behind both these panels:
The wire terminated in the back of the battery compartment but did not go to the roof. I didn't see a good way to drill up to the roof from either location (they're close to the roof edge). It would be easier to drill up to the roof from the cabinet between the arrows, and it's possible to connect to the prewire from there (probably with a bit of exposed wire in the top of the cabinet). Depends on your floorplan of course.
I decided the best way to hide the solar install was to drill up to the roof from above the pantry and run new wire. In the UMB it's easy to route wire from battery or inverter to the pantry. The solar charge controller wouldn't fit in the battery compartment but it did fit next to the inverter.
