If I hit a bad pothole at speed I hear a "crunch" ( Ist time I thought it was the front windscreen cracked)
Have checked under the vehicle, front spring on the bottom appears OK, distance between the driver side rubber bump stop and the metal base is around 12mm, passenger side around 22mm.
Ground to Mudguard on Driver side 12mm less than Passenger side.
I do not seem to be able to push down on the front of the vehicle to test the shocks, however when I jacked the front up and let it down again I was to rock the front up and down more easily. ( Maybe there is no gas in them?)
In a process of elimination do I replace the front shocks.
Appreciate your comments
Peter
Peter
