Kajtek1
2015 3500 X long limo RV
Making DIY conversion is not an easy project and there are thousands of unfinished ones sitting in garages, or under the tree.
Start with buying inverter/charger. A bit more money than separate units, but much simpler and space-saving.
If all you need 120V for is AC and single kitchen outlet - inverter breaker will do.
For more 120V outlets you will need to build 120V breaker panel.
I made my conversion with 30 amp cable, so I don't need to turn AC off to use microwave, or coffeemaker.
Propane is adding lot of troubles to design.
Since my I4 diesel just sips fuel, I design it to work as generator when I need electric power for my fridge and water heater.
