27" x 27" Corner Shower Pan with Center Drain for van conversion
Surfawave69
Bought this shower pan for a van conversion but it really didn't fit our layout. Bought another one instead.
Has never been used and is in perfect condition. Ready to be installed in an RV, boat, van, etc.
Local Bay Area sale only...no shipping.
Price: $80
01111_7CzTeXcMahT_0CI0t2_1200x900.jpg00404_anMGfOU45QC_0mo0jw_1200x900.jpg00K0K_9vZ7MrK4jBs_0CI0t2_1200x900.jpg00H0H_lrt61bbhIQa_0CI0t2_1200x900.jpg
Retail Description:
RV shower pan has a front drain hole and an access door that lets you easily reach your pipes for maintenance. Flange prevents your wall from getting water damage. Durable ABS plastic construction is lighter and more eco-friendly than fiberglass.
Features:
Shower pan replaces or upgrades your existing RV or camper shower pan
Has a front drain hole setup
Access door on the front of the shower pan lets you easily reach your pipes for maintenance
3-Sided tile flange helps prevent water from seeping behind the shower pan and damaging the wall
Textured, anti-slip bottom reduces the chance of falls
Flat rim of the shower pan holds soap, shampoo bottles, and other toiletries
Durable, scratch-resistant ABS thermoplastic polymer construction
Lighter and more environmentally-friendly than fiberglass
Pre-installed foam base prevents cracking and provides sound dampening
Parchment color
IAPMO certified, CSA compliant, and ASME certified
Bolt-on installation - hardware not included
Made in the USA
Specs:
Overall exterior dimensions:
Side to side: 27" long x 27" wide
Corner to corner: 37-5/8" long x 31" wide
Overall interior dimensions
Side to side: 20-3/4" long x 20-3/4" wide
Corner to corner: 29" long x 24-1/4" wide
Overall height: 10-7/8"
Drain hole diameter: 2"
