Wrinkledpants
2017 144WB 4x4
I’ve had limited success with blipping the throttle in park to get the revs above idle. Times when I expected to have the no power, but blipped the throttle, I had normal power. I’ll keep trying this method.
i agree stop wasting your time. it has been well documented that vw,mb, and bmw used defeat devices at outset. they are illegal vehicles under carb and epa. manufactures are or will pay fines and restitution. that said we are still using vehicles that have been documented to be out of whack as much as 10 tens or more of what they report. if you are as resolute as you are stop driving your sprinter now. your govt would rather have the money than crush your car.You choose to consistently ignore the carefully curated references to the actual law and its accompanying regulations which I have provided. Instead, you keep repeating obvious falsehoods in contradiction to this information.
I am going to stop wasting my time.
This really helps with my decision to go with Renntech!I also forgot to mention, I returned 18.2mpg from Mission Viejo to Williams and back. Return trip was into absurd headwinds/crosswinds the kicked the sway assist 3 times. 75mph each way. This would usually be a 16mpg affair for me. In 40-50K miles the tune will pay for itself in fuel savings.
Picked mine up from OwlVans. Great company to work with. Think pricing is pretty flat across the board, Renntech seems to have a strong MAP policy.Where is the best pricing?
Classy guy.>> Avanti
i got my complete stage 2 jr tune from tunemyeuro.com total including dpf bypass pipe was $850. i went from 16.5 mpg hiway to 20mpg at 65-70mph. no egr, no egr cooler, no dpf , no swirl motor issuesThis really helps with my decision to go with Renntech!
>> Avanti
Year,engine?i got my complete stage 2 jr tune from tunemyeuro.com total including dpf bypass pipe was $850. i went from 16.5 mpg hiway to 20mpg at 65-70mph. no egr, no egr cooler, no dpf , no swirl motor issues
2007 0m642. 165000 when i did tune, 172000 now. did tune in 2018Year,engine?
That site doesn't seem to have anything for VS30 Sprinters.i got my complete stage 2 jr tune from tunemyeuro.com total including dpf bypass pipe was $850. i went from 16.5 mpg hiway to 20mpg at 65-70mph. no egr, no egr cooler, no dpf , no swirl motor issues
contact them on phone. is yours an 0m642 engineThat site doesn't seem to have anything for VS30 Sprinters.
Why would you do an emissions delete on a VS30?? Talk about murdering the resale on your van, driving something that STINKS like a diesel outboard, and raising a giant flag pretty much anywhere you take the van to get work done on it. Oh, you know, and dumping tons of NOx and particulates.That site doesn't seem to have anything for VS30 Sprinters.
I wouldn't. But my point was that posting a site that doesn't have VS30 stuff doesn't seem super productive.Why would you do an emissions delete on a VS30??
Good to hear.Data Point: Cold soak overnight in low 20's. Went out in the morning and started the van. Van registered outside air temp at 29 deg. Elevation 8100 ft. Renntech tune.
Van had power immediately upon start. No cold start issues whatsoever. Put it in reverse and backed up: Van seemed like it was struggling to move, but then realized the parking brake was on. So even with parking brake on, cold soak, high altitude, van had power to overcome parking brake and move. Pulling into main road was typical reduction in immediate power with altitude but still substantially better than stock.
You will want to flash it back to stock before going for a smog inspection otherwise you will fail. Takes 2 minutes to switch it back to stock... That's the beauty of the HHT (Hand Held Tuner).Any issues passing CA emissions testing with tune installed?
