Kajtek,
I can't help you with anything since your understanding of what a scanner is vs Vladimir's module is limited. Vladimir's module is not a scanner, but is closer to a programmer... Do you understand the difference at least?
The device doesn't scan for anything, once it is plugged in the OBD port it starts running a script with certain commands in order to unlock and reset. The way to know that for sure is, plug the device in a van that has no problems with start countdown and the device will do exactly the same thing as it would do on a van with start countdown triggered. I have actually done that very thing since I do own the device...
What exactly of what I said is not truth? Can you elaborate?
Next time Kajtek, try not to compare хуй с пальцем... Vladimir's module is not on par with Vediamo software in terms of capabilities.
