NCV3: 2006-2018 Used DTE PedalBox for 2007-2018 Sprinters for sale $150 Aurora CO
crashman
I traded in my Sprinter and don't need this anymore it is in great shape and set to work best with the diesel programmer
$150
DTE PedalBox for late model Sprinters
The PedalBox changes the characteristics of the throttle pedal. Vehicles are designed for the “average” and to suit all conditions. The PedalBox optimizes the throttle response, and removes the factory “lag”.
The PedalBox Reduces the pedal travel required to reach the “Throttle Wide Open” position.
  • Suitable for Gasoline or Diesel engines
  • Suitable for manual or automatic transmissions
  • Reduced lag on automatic gear changes
  • Transmission applies power evenly
  • Ready to use in seconds
  • Sprinter specific programming
Certifications.
The PedalBox is certified by UN ECE R10 for automotive usage in all UN/ECE and
associated countries worldwide (www.unece.org) .
PedalBox further is CE approved for use in the European Union.
PedalBox is designed and made by DTE Systems GmbH in Germany. DTE Systems GmbH
is regularly verified based on ISO 9001 by TÜV Austria for production of automotive parts
compliant to German and International road traffic laws.
Safety standards.
Electronic throttle. All electronic throttles installed in certified cars have to comply with strict
safety standards, including redundant signal paths and specific protocols to ensure the safe
functioning of the throttle at all times. The ECU constantly monitors the throttle’s safety
signals to prevent malfunctioning and unintended acceleration or deceleration.
The PedalBox is designed in a way that ensures that all required safety measures of the
original throttle continue to work as intended. Through redundant components and signal
paths, the PedalBox ensures and complies to the same safety mechanisms as the original
throttle itself. Thus, the ECU’s safety mechanisms are kept active and remain unchanged by
an installation – any potential malfunctioning of the throttle including the connected PedalBox
remains to be traceable.
Other vehicle parts. The PedalBox is connected solely to the electronic throttle and does not
have any direct effect on other parts like engine, engine management systems, gear box,
turbo or ECU. By design, there are no changes whatsoever in original vehicle parts,
registered engine characteristics such as power or torque, emissions or braking behavior
beyond the original car’s working range with an analogous, appropriate driving pattern. As
the device only influences the existing throttle signal, the functioning of the device equals an
adjusted way of how a driver physically pushes or releases the throttle. Such as various
drivers have different ways of how to use the throttle, the PedalBox creates an adjusted
driver behavior within the original range of the throttle.
