I am running rock lights along the side of the van and rear. Probably 8 lights total at 9 watts a piece. This puts me at 6 amps I think. I'm using the BlueSea wire calculator. My questions is about the length. I'll come off the Aux battery under the hood thru an inline fuse, in the dash, to a switch, and back out. Then I'll grab a negative from the battery creating a switched and fused power source. I'll split that into a driver and passenger side run. When determining wire size, the initial part will carry full load and then it will be split. Do I calculate the first (short part) based on all the lights, and then each "string" off of it based on their individual length and the number of lights? I'm a bit confused.
My current plan is 14 ga to the switch and the long run with more lights and 16ga to the one with less lights.
