Power steering not working- PSF turned black
I tried topping up the power steering fluid, and that hasn't helped so far. It was yellowish when I put it in, and now it's black. I did use some very old, non-ATF+4 stuff. Should I drain the try ATF+4 first
jrod5150
Bad racks are becoming more and more common. Fluid doesn’t matter as the post above states. Almost any atf or Power steering fluid is fine
