My Dometic fridge cooling unit failed.
I installed a new dorm size Fridge with an inverter. The inverter is a 2000 with peak at 3000. With two 250ah deep cycle Batts. Voltages are all good.
My problem is while traveling, the inside of fridge warms up to 50*
I have 2.5" of airflow around the fridge for venting.
I'm using a modified inverter, I now know it should be a pure sine one.
But, is my problem because these compressor type fridges shouldn't be going up and down the road or too high of outside temperature (sun)?
Anyone have and solved this type of issue?
Thank you for your help.
