Programming a Victron Multiplex before installation
JIB
I am waiting on some system components so I can power up my electrical system but want to get started on programming my Multiplex 24/3000 now. Is there any reason I can't/shouldn't wire up a 120v pigtail to the inverter to power it (i.e. shore power), so I can start entering the appropriate values?
Thanks in advance,
Jack
RVBarry
Hi, it shouldn't blow up.
What do the docs or reseller say?
JIB
I've not found a reference to this yet. The docs discuss connecting everything and programming.
Geriakt
2017 View 24J
You can do all the programing of the Multiplus 24/3000 with the Victron Connect software without being connected to the inverter. Then you save the file and when you first start up the Multiplus after your install, load the saved file and you are done.
