Swap TPMS control module across years
MIK3
Does anyone know if the TPMS control module can be swapped from a 2019 to a 2010 as a plug in changeout? Since my wheels are the 433 frequency and my van control is 315, I think it would be far easier and less costly to swap the module if it will work. :idunno:
1seven1
Hey MIK3, did you ever figure this out? I've got a 2011 3500 without TPMS, and I'd sure love to add the factory system. I *think* I need a 315mhz system with the Mercedes 0025407545 control module, but I'm having a hell of a time figuring it out for sure. Thx
manwithgun
Haven’t heard of a NCV3 Sprinter that didn’t have TPMS. Try running your VIN through one of the vin-checkers which will provide your vehicles build spec. Somewhere in that information you’ll likely find the tpms or 315mhz mentioned. Sure yours could be absent but most come as standard.
1seven1
Thanks. Good tip. I will. It's a Winnebago View, so it wouldn't surprise me if they went cheap on the chassis for the $130k RV. :-/
1seven1
I'm not seeing it listed. Looks like a special tire config. So stupid. Ideas on where I can identify the proper TPMS Control Module for this VIN? I'd much rather source OE parts than deal with some aftermarket bolt-on system. Thank in advance for the tips. Much appreciated. Here's the listing results:
FIN WDA9061551N470589
VIN WDAPF4CC4B9470589
Model 519 4X2 4325
Engine 642898 41 073532
Transmission 722683 8 357111
Order Number 7 1 740 13816
Order Location MB USA
Paint 1 PAINT COLOR ARCTIC WHITE MB 9147 (9147)
Release Date 2010-12-01
Delivery Date 2010-12-06
Code Description
181 FUEL FILTER WITH WATER SEPARATOR
281K ALTERNATOR, AIR-COOLED, 220 A
423 5-SPEED AUTOMATIC TRANSMISSION
494 VERSION FOR USA
581 AUTOMATIC CLIMATE CONTROL
617K FUEL FILTER WITH WATER SEPARATOR
801 YOM 10/1
938K ENGINE, LOW-EMISSION EPA 10/CARB
A50 FRONT AXLE WITH INCREASED CARRYING LOAD
AR2 AXLE RATIO I = 3.923
BB3 ELECTRONIC STABILITY PROGRAM (ESP)
BE2 HAND BRAKE LEVER, FOLDABLE
C33 REAR SPRING, HARDER
C45 H.D. FRONT AXLE STABILIZER
CE8 RAISED BODY
CF5 CHASSIS FOR APPLICATION D
CF6 FRONT SPRING AND DAMPER REINFORCED
CL1 STEERING WHEEL ADJUSTABLE IN INCLINATION & HEIGHT
E07 HILL-START ASSIST
E30 BATTERY MASTER SWITCH, ONE-PIN
E40 TRAILER PLUG SOCKET,7-POLE
ED8 ELECTRICAL SYST. PREINST., PARAM. SPECIAL MODULE
EE8 12V BATTERY 100 AH
EK1 TERMINAL STRIP FOR ELECTRICAL CONNECTION
EL8 TWO-WAY LOUDSPEAKER FRONT
ER0 RADIO PREINSTALLATION
ES0 JUMP START CONTACT
F66 LOCKABLE GLOVE COMPARTMENT
F68 HEATED AND ELECTRICALLY ADJUSTABLE OUTSIDE MIRROR
FF5 STOWAGE BOX/TRAY ABOVE WINDSHIELD
FI1 REMOTE CONTROL KEY SYSTEM FREQUENCY 315 MHZ
FS2 EXTRA LONG MIRROR HOLDER
FW1 ELIMINATION CAB REAR PANEL
G40 AUTOMATIC TRANSMISSION
H21 ALL-RND.HEAT ABSORB.GL.W.BAND FLTR ON FR.WINDOW
HH2 ELECTRICALLY POWERED HOT-AIR AUXILIARY HEATER
HH9 SEMI-AUTOMATICALLY CONTROLLED TEMPMATIC A/C
IG3 SPRINTER STANDARD
J11 SPEEDOMETER MPH AND KM/H
J58 SEAT BELT WARNING SYSTEM FOR DRIVER SEAT
J65 OUTSIDE TEMPERATURE INDICATOR
JW2 LAMP FAILURE INDICATOR DEACTIVATION
K60 TAIL PIPE LEADING STRAIGHT TO THE REAR
KB0 MAIN TANK 100 LITER
KL1 FUEL-LEVEL SENSOR FOR AUXILIARY HEATER
KL5 FUEL FILTER WITH WATER SEPARATOR
KP0 BODYSHELL SCOPES FOR SCR
L05 AUTOMATIC DAYTIME RUNNING LIGHTS FOR USA/CANADA
L76 TAILLAMP LINE EXTENDED
L90 TAIL LAMP DELETED
L94 ELIMINATION OF PARKING LIGHT
LD0 OVERHEAD CONTROL PANEL WITH 2 READING SPOTLIGHTS
M46 14 V/220 A ALTERNATOR
MG5 ENGINE OM642 DE30LA 140KW (190HP) 3800RPM
MH1 ENGINE, LOW-EMISSION EPA 10/CARB
MS1 TEMPOMAT (CRUISE CONTROL)
MZ0 BLUEEFFICIENCY
P08 COVER FOR TRANSPORT
P47 MUDFLAP FRONT
PY3 CUSTOMER WINNEBAGO L-LINE
Q18 END CROSS MEMBER BOLTED
R60 SPARE WHEEL CARRIER PROV. TO FRAME
R87 SPARE WHEEL
RF1 TIRE MANUFACTURER CONTINENTAL (10)
RH7 TYRES LT 215/85 R16
RM0 ALL-SEASON TIRE
RM9 TIRE MAKE SPECIAL REQUEST
RS6 STEEL WHEELS 5.5J X 16
RW4 NO TIRE REPAIR KIT AND COMPRESSOR
S22 DRIVER'S SEAT ARMREST
S25 CO-DRIVER'S SEAT ARMREST
S87 DRIVER SEAT FRAME, LOW
S88 FRONT PASSENGER SEAT FRAME, LOW
SA5 AIRBAG DRIVER SIDE
SA6 CO-DRIVER'S AIR BAG
SB1 DRIVER SEAT, COMFORT
SB2 PASSENGER SEAT, COMFORT
SD2 SEAT BELT ON B-PILLAR
SR8 DRIVER SEAT BOGIE
SR9 FRONT PASSENGER SEAT BOGIE
V85 SMOKER PACKAGE
VH5 LIMA BLACK FABRIC
X42 PLATES / PRINTED MATERIALS ENGLISH
XC8 VIN VISIBLE FROM OUTSIDE
XY1 MODEL YEAR 1
Y43 HYDRAULIC JACK
Z44 REGISTRATION OF VEHICLE NOT POSSIBLE IN EU
ZU8 USA COUNTRY VERSION
ZZ4 MERCEDES-BENZ SCOPE OF BRANDS, NORTH AMERICA
3500's where never fitted with factory TPMS as it was only a legal requirement on 2500's.
I believe a 3500 is above the max GVWR that legally requires TPMS.
1seven1
Thanks, Keith! That would explain why I'm having so much trouble figuring this out. 6 wheels ... kind of makes sense. :rolleyes:
MIK3
I have realized the wheels from a 2019 2500 use 433 MHz while I understand the 2010-2018 models use 315 MHz. I have not determined if I can simply swap modules as there is nothing out there on that. I suspect its possible that it may work, but there's a possibility if the computer receiving the data may need a different signal. I'm willing to give it a try but the new module was over $400 which is insane. I'll wait until I come across one from a wreck or when they become common on eBay for $50.
