Transmission not shifting
maxzoom
With out warning my 2006 Sprinter with 114,000 is not shifting faster then 20 mph. You can still go 30 but it's not shifting (noisier and heating up). Also the P, N, R, and D letters on the dash have disappeared. Park, neutral, reverse, and drive still work but those indicator letters are gone. I got the code U0101 and P0088. Also the ABS, ESP, and that traction control lights went on later too.
I checked the fuses on the battery, under the seat, and under the steering wheel and they look ok.
Any help is needed as this van is used for taxi service. So for now we are out of service/out of business.
hkpierce
'02 140 Hi BlueBlk Pass
Flipping through my The Complete Sprinter Fault Code Guide, I see no codes with a prefix of "U". What code reader are you using?
maxzoom
I'm using "ScanGauge. U0101 "Lost Comm with TCM" I do have a iSOFT MBII. I'll hook that up and see what it shows.
Here are the U-codes i'm aware of:
U0001 Hi Speed CAN Comm Bus_
U0002 Hi Speed CAN Comm Bus Perf_
U0003 Hi Speed CAN Comm Bus + Open_
U0004 Hi Speed CAN Comm Bus + Low_
U0005 Hi Speed CAN Comm Bus + Hi_
U0006 Hi Speed CAN Comm Bus - Open_
U0007 Hi Speed CAN Comm Bus - Low_
U0008 Hi Speed CAN Comm Bus - Hi_
U0009 Hi Speed CAN Comm Bus - shorted to Bus +_
U0010 Medium Speed CAN Comm Bus_
U0011 Medium Speed CAN Comm Bus Perf_
U0012 Medium Speed CAN Comm Bus + Open_
U0013 Medium Speed CAN Comm Bus + Low_
U0014 Medium Speed CAN Comm Bus + Hi_
U0015 Medium Speed CAN Comm Bus - Open_
U0016 Medium Speed CAN Comm Bus - Low_
U0017 Medium Speed CAN Comm Bus - Hi_
U0018 Medium Speed CAN Comm Bus - shorted to Bus +_
U0019 Low Speed CAN Comm Bus_
U0020 Low Speed CAN Comm Bus Perf_
U0021 Low Speed CAN Comm Bus + Open_
U0022 Low Speed CAN Comm Bus + Low_
U0023 Low Speed CAN Comm Bus + Hi_
U0024 Low Speed CAN Comm Bus - Open_
U0025 Low Speed CAN Comm Bus - Low_
U0026 Low Speed CAN Comm Bus - Hi_
U0027 Low Speed CAN Comm Bus - shorted to Bus +_
U0028 Vehicle Comm Bus A_
U0029 Vehicle Comm Bus A Perf_
U0030 Vehicle Comm Bus A + Open_
U0031 Vehicle Comm Bus A + Low_
U0032 Vehicle Comm Bus A + Hi_
U0033 Vehicle Comm Bus A - Open_
U0034 Vehicle Comm Bus A - Low_
U0035 Vehicle Comm Bus A - Hi_
U0036 Vehicle Comm Bus A - shorted to Bus A +_
U0037 Vehicle Comm Bus B_
U0038 Vehicle Comm Bus B Perf_
U0039 Vehicle Comm Bus B + Open_
U0040 Vehicle Comm Bus B + Low_
U0041 Vehicle Comm Bus B + Hi_
U0042 Vehicle Comm Bus B - Open_
U0043 Vehicle Comm Bus B - Low_
U0044 Vehicle Comm Bus B - Hi_
U0045 Vehicle Comm Bus B - shorted to Bus B +_
U0046 Vehicle Comm Bus C_
U0047 Vehicle Comm Bus C Perf_
U0048 Vehicle Comm Bus C + Open_
U0049 Vehicle Comm Bus C + Low_
U0050 Vehicle Comm Bus C + Hi_
U0051 Vehicle Comm Bus C - Open_
U0052 Vehicle Comm Bus C - Low_
U0053 Vehicle Comm Bus C - Hi_
U0054 Vehicle Comm Bus C - shorted to Bus C +_
U0055 Vehicle Comm Bus D_
U0056 Vehicle Comm Bus D Perf_
U0057 Vehicle Comm Bus D + Open_
U0058 Vehicle Comm Bus D + Low_
U0059 Vehicle Comm Bus D + Hi_
U0060 Vehicle Comm Bus D - Open_
U0061 Vehicle Comm Bus D - Low_
U0062 Vehicle Comm Bus D - Hi_
U0063 Vehicle Comm Bus D - shorted to Bus D +_
U0064 Vehicle Comm Bus E_
U0065 Vehicle Comm Bus E Perf_
U0066 Vehicle Comm Bus E + Open_
U0067 Vehicle Comm Bus E + Low_
U0068 Vehicle Comm Bus E + Hi_
U0069 Vehicle Comm Bus E - Open_
U0070 Vehicle Comm Bus E - Low_
U0071 Vehicle Comm Bus E - Hi_
U0072 Vehicle Comm Bus E - shorted to Bus E +_
U0073 Control Mod Comm Bus Off_
U0100 Lost Comm with ECM/PCM A_
U0101 Lost Comm with TCM_
U0102 Lost Comm with Transfer Case Control Mod_
U0103 Lost Comm with Gear Shift Mod_
U0104 Lost Comm with Cruise Control Mod_
U0105 Lost Comm with Fuel Injector Control Mod_
U0106 Lost Comm with Glow Plug Control Mod_
U0107 Lost Comm with Throttle Actuator Control Mod_
U0108 Lost Comm with Alternative Fuel Control Mod_
U0109 Lost Comm with Fuel Pump Control Mod_
U0110 Lost Comm with Drive Motor Control Mod_
U0111 Lost Comm with Battery Energy Control Mod A_
U0112 Lost Comm with Battery Energy Control Mod B_
U0113 Lost Comm with Emissions Critical Control Information_
U0114 Lost Comm with 4-Wheel Drive Clutch Control Mod_
U0115 Lost Comm with ECM/PCM B_
U0121 Lost Comm with ABS (ABS) Control Mod_
U0122 Lost Comm with Vehicle Dynamics Control Mod_
U0123 Lost Comm with Yaw Rate Sensor Mod_
U0124 Lost Comm with Lateral Acceleration Sensor Mod_
U0125 Lost Comm with Multi-axis Acceleration Sensor Mod_
U0126 Lost Comm with Steering Angle Sensor Mod_
U0127 Lost Comm with Tire Press Monitor Mod_
U0128 Lost Comm with Park Brake Control Mod_
U0129 Lost Comm with Brake Sys Control Mod_
U0130 Lost Comm with Steering Effort Control Mod_
U0131 Lost Comm with Power Steering Control Mod_
U0132 Lost Comm with Ride Level Control Mod_
U0133 Reserved by Document_
U0134 Reserved by Document_
U0135 Reserved by Document_
U0136 Reserved by Document_
U0137 Reserved by Document_
U0138 Reserved by Document_
U0139 Reserved by Document_
U0140 Lost Comm with Body Control Mod_
U0141 Lost Comm with Body Control Mod A_
U0142 Lost Comm with Body Control Mod B_
U0143 Lost Comm with Body Control Mod C_
U0144 Lost Comm with Body Control Mod D_
U0145 Lost Comm with Body Control Mod E_
U0146 Lost Comm with Gateway A_
U0147 Lost Comm with Gateway B_
U0148 Lost Comm with Gateway C_
U0149 Lost Comm with Gateway D_
U0150 Lost Comm with Gateway E_
U0151 Lost Comm with Restraints Control Mod_
U0152 Lost Comm with Side Restraints Control Mod Left_
U0153 Lost Comm with Side Restraints Control Mod Right_
U0154 Lost Comm with Restraints Occupant Sensoring Control Mod_
U0155 Lost Comm with Instrument Panel Cluster Control Mod_
U0156 Lost Comm with Information Center A_
U0157 Lost Comm with Information Center B_
U0158 Lost Comm with Head Up Display_
U0159 Lost Comm with Parking Assist Control Mod_
U0160 Lost Comm with Audible Alert Control Mod_
U0161 Lost Comm with Compass Mod_
U0162 Lost Comm with Navigation Display Mod_
U0163 Lost Comm with Navigation Control Mod_
U0164 Lost Comm with HVAC Control Mod_
U0165 Lost Comm with HVAC Control Mod Rear_
U0166 Lost Comm with Auxiliary Heater Control Mod_
U0167 Lost Comm with Vehicle Immobilizer Control Mod_
U0168 Lost Comm with Vehicle Security Control Mod_
U0169 Lost Comm with Sunroof Control Mod_
U0170 Lost Comm with Restraints Sys Sensor A_
U0171 Lost Comm with Restraints Sys Sensor B_
U0172 Lost Comm with Restraints Sys Sensor C_
U0173 Lost Comm with Restraints Sys Sensor D_
U0174 Lost Comm with Restraints Sys Sensor E_
U0175 Lost Comm with Restraints Sys Sensor F_
U0176 Lost Comm with Restraints Sys Sensor G_
U0177 Lost Comm with Restraints Sys Sensor H_
U0178 Lost Comm with Restraints Sys Sensor I_
U0179 Lost Comm with Restraints Sys Sensor J_
U0180 Lost Comm with Automatic Lighting Control Mod_
U0181 Lost Comm with Headlamp Leveling Control Mod_
U0182 Lost Comm with Lighting Control Mod Front_
U0183 Lost Comm with Lighting Control Mod Rear_
U0184 Lost Comm with Radio_
U0185 Lost Comm with Antenna Control Mod_
U0186 Lost Comm with Audio Amplifier_
U0187 Lost Comm with Digital Disc Player/Changer Mod A_
U0188 Lost Comm with Digital Disc Player/Changer Mod B_
U0189 Lost Comm with Digital Disc Player/Changer Mod C_
U0190 Lost Comm with Digital Disc Player/Changer Mod D_
U0191 Lost Comm with Television_
U0192 Lost Comm with Personal Computer_
U0193 Lost Comm with Digital Audio Control Mod A_
U0194 Lost Comm with Digital Audio Control Mod B_
U0195 Lost Comm with Subscription Entertainment Rcvr Mod_
U0196 Lost Comm with Rear Seat Entertainment Control Mod_
U0197 Lost Comm with Telephone Control Mod_
U0198 Lost Comm with Telematic Control Mod_
U0199 Lost Comm with Door Control Mod A_
U0200 Lost Comm with Door Control Mod B_
U0201 Lost Comm with Door Control Mod C_
U0202 Lost Comm with Door Control Mod D_
U0203 Lost Comm with Door Control Mod E_
U0204 Lost Comm with Door Control Mod F_
U0205 Lost Comm with Door Control Mod G_
U0206 Lost Comm with Folding Top Control Mod_
U0207 Lost Comm with Moveable Roof Control Mod_
U0208 Lost Comm with Seat Control Mod A_
U0209 Lost Comm with Seat Control Mod B_
U0210 Lost Comm with Seat Control Mod C_
U0211 Lost Comm with Seat Control Mod D_
U0212 Lost Comm with Steering Column Control Mod_
U0213 Lost Comm with Mirror Control Mod_
U0214 Lost Comm with Remote Function Actuation_
U0215 Lost Comm with Door Switch A_
U0216 Lost Comm with Door Switch B_
U0217 Lost Comm with Door Switch C_
U0218 Lost Comm with Door Switch D_
U0219 Lost Comm with Door Switch E_
U0220 Lost Comm with Door Switch F_
U0221 Lost Comm with Door Switch G_
U0222 Lost Comm with Door Window Motor A_
U0223 Lost Comm with Door Window Motor B_
U0224 Lost Comm with Door Window Motor C_
U0225 Lost Comm with Door Window Motor D_
U0226 Lost Comm with Door Window Motor E_
U0227 Lost Comm with Door Window Motor F_
U0228 Lost Comm with Door Window Motor G_
U0229 Lost Comm with Heated Steering Wheel Mod_
U0230 Lost Comm with Rear Gate Mod_
U0231 Lost Comm with Rain Sensoring Mod_
U0232 Lost Comm with Side Obstacle Detection Control Mod Left_
U0233 Lost Comm with Side Obstacle Detection Control Mod Right_
U0234 Lost Comm with Convenience Recall Mod_
U0235 Lost Comm with Cruise Control Front Distance Range Sensor_
U0300 Internal Control Mod Software Incompatibility_
U0301 Software Incompatibility with ECM/PCM_
U0302 Software Incompatibility with Trans Control Mod_
U0303 Software Incompatibility with Transfer Case Control Mod_
U0304 Software Incompatibility with Gear Shift Control Mod_
U0305 Software Incompatibility with Cruise Control Mod_
U0306 Software Incompatibility with Fuel Injector Control Mod_
U0307 Software Incompatibility with Glow Plug Control Mod_
U0308 Software Incompatibility with Throttle Actuator Control Mod_
U0309 Software Incompatibility with Alternative Fuel Control Mod_
U0310 Software Incompatibility with Fuel Pump Control Mod_
U0311 Software Incompatibility with Drive Motor Control Mod_
U0312 Software Incompatibility with Battery Energy Control Mod A_
U0313 Software Incompatibility with Battery Energy Control Mod B_
U0314 Software Incompatibility with 4WDClutch Control Mod_
U0315 Software Incompatibility with ABS Control Mod_
U0316 Software Incompatibility with Vehicle Dynamics Control Mod_
U0317 Software Incompatibility with Park Brake Control Mod_
U0318 Software Incompatibility with Brake Sys Control Mod_
U0319 Software Incompatibility with Steering Effort Control Mod_
U0320 Software Incompatibility with Power Steering Control Mod_
U0321 Software Incompatibility with Ride Level Control Mod_
U0322 Software Incompatibility with Body Control Mod_
U0323 Software Incompatibility with Instrument Panel Control Mod_
U0324 Software Incompatibility with HVAC Control Mod_
U0325 Software Incompatibility with Auxiliary Heater Control Mod_
U0326 Software Incompatibility with Veh Immobilizer Control Mod_
U0327 Software Incompatibility with Vehicle Security Control Mod_
U0328 Software Incompatibility with Steering Angle Sensor Mod_
U0329 Software Incompatibility with Steering Column Control Mod_
U0330 Software Incompatibility with Tire Press Monitor Mod_
U0331 Software Incompatibility with Body Control Mod A_
U0400 Invalid Data Received_
U0401 Invalid Data Received From ECM/PCM_
U0402 Invalid Data Received From Trans Control Mod_
U0403 Invalid Data Received From Transfer Case Control Mod_
U0404 Invalid Data Received From Gear Shift Control Mod_
U0405 Invalid Data Received From Cruise Control Mod_
U0406 Invalid Data Received From Fuel Injector Control Mod_
U0407 Invalid Data Received From Glow Plug Control Mod_
U0408 Invalid Data Received From Throttle Actuator Control Mod_
U0409 Invalid Data Received From Alternative Fuel Control Mod_
U0410 Invalid Data Received From Fuel Pump Control Mod_
U0411 Invalid Data Received From Drive Motor Control Mod_
U0412 Invalid Data Received From Battery Energy Control Mod A_
U0413 Invalid Data Received From Battery Energy Control Mod B_
U0414 Invalid Data Received From 4-Wheel Drive Clutch Control Mod_
U0415 Invalid Data Received From ABS Control Mod_
U0416 Invalid Data Received From Vehicle Dynamics Control Mod_
U0417 Invalid Data Received From Park Brake Control Mod_
U0418 Invalid Data Received From Brake Sys Control Mod_
U0419 Invalid Data Received From Steering Effort Control Mod_
U0420 Invalid Data Received From Power Steering Control Mod_
U0421 Invalid Data Received From Ride Level Control Mod_
U0422 Invalid Data Received From Body Control Mod_
U0423 Invalid Data Received From Instrument Panel Control Mod_
U0424 Invalid Data Received From HVAC Control Mod_
U0425 Invalid Data Received From Auxiliary Heater Control Mod_
U0426 Invalid Data Received From Vehicle Immobilizer Control Mod_
U0427 Invalid Data Received From Vehicle Security Control Mod_
U0428 Invalid Data Received From Steering Angle Sensor Mod_
U0429 Invalid Data Received From Steering Column Control Mod_
U0430 Invalid Data Received From Tire Press Monitor Mod_
U0431 Invalid Data Received From Body Control Mod A_
Have you checked the electrical plug on the transmission for signs of fluid leaks and then the plug onto the TCM under the drivers seat for oil contamination?
maxzoom
Thanks for your post. I just went under there and checked... what a leak and what a mess. Is it the electrical plug that is doing all the leaking?
OK That is a mess!
Now head under the drivers seat and unplug the TCM...
maxzoom
This morning I took out the drivers seat. And took out the TCM bracket for a close look at the TCM and checked transmission relay #5. I didn't see any oil or water under the seat or connections. Why unplug the TCM under the driver's seat?
Patrick of M
2005 T1N 2500 (NA spec)
To see if transmission fluid wicked up into the TCM, it happens. Damn that is a dirty transmission, make sure you clean that all up before opening anything.
maxzoom
Yes, time to change trans fluid and seal. Ok I'll unplug the TCM first. And luckily I have a new "Guide Bushing" for the electrical connecter so I will do that too.
maxzoom
That electrical plug is where the leak was coming from. Just having trouble disconnecting the 13 pin connector. Any hints on how to remove and reinstall that plug.
Thanks, Tim
F i g . 1 2 4 R e m o v e W i r i n g C o n n e c t o r P l u g
1 - PLUG CONNECTOR
2 - GUIDE BUSHING
5) Disconnect 13-pin plug connector (1) (Fig. 124). Turn bayonet lock of guide bushing (2) anti-clockwise.
(6) Loosen guide bushing (2) and remove from transmission housing.
Hellshalfacre
2005, 2500
For the connector removal, disconnect the negative cable so you don't short anything out, clean that plug and surrounding area really well with some contact cleaner. If your van has a cover with a zip tie on the connector just snip the zip tie and remove the plastic cover. Then turn the white portion of the adapter plug with the blade piece downward. If it's stuck a stout flatblade can be used for leverage but be careful as the plastic can become brittle. It should be doable by hand with a little patience. Once the blade of the adapter plug is facing downward the 13 pin connector will release. Pull it out, and with a deep 7mm socket losen the single bolt holding the adapter in place. The bolt is captive and stays with the apdapter. Then pull the adapter out. Clean the 13p connector with contact cleaner to get all the oil out. There are some great threads on reassembly but it's pretty straight forward: lube orings, Index adapter and seat by hand. Tighten bolt carefully and with a surprisingly small amount of torque. Reinstal plug. One of the easier maintenance items on the van. Youll want to drain trans fluid first.
jrod5150
With the IC display showing blank I’d go with the tcm. Changing the electrical plug on the trans is also a good idea since it may have been the cause of death for the Tcm. I’ve had a few bad tcms lately with no signs of fluid near them. Of course proper testing is the best way to be sure but tcms are cheap...
maxzoom
"With out warning my 2006 Sprinter with 114,000 is not shifting faster then 20 mph". I'd like to say there was a warning... That morning I was driving that van and everything was good. My wife took over driving that taxi in the afternoon. A few hours later she came home and said there is something wrong. She said there was a sudden loss of power and it was overheating.
All day yesterday (most of the time was clean-up); disconnect negative battery, take off drivers seat, check and unplug the TCM, drain the transmission fluid in the pan (only about two quarts there), put in new filter and transmission seal, disconnect electrical plug, install a new "guide bushing" , plug back in the connector, put in transmission fluid, plug back in the TCM, reconnect the battery, and test drive.
Turn on engine and still not showing P, N, R, and D display. Park, Neutral , and Reverse work ok. But transmission Drive is still not shifting up, like stuck in 2nd gear.
PS.... We are driving on some unpaved roads. It was dry and dusty the last few days. That's how all that mess under the transmission happened. Next time I will check under there more often.
maxzoom
"Tighten bolt carefully and with a surprisingly small amount of torque. Reinstal plug. One of the easier maintenance items on the van. Youll want to drain trans fluid first".
Thanks with your help with that. I tightened that bolt as hard as I can by hand. I didn't want to torque with a ratchet because that little bolt, with not much thread, looks too easy to strip.
maxzoom
maxzoom
Thanks, I'm going to look into TCMs and changing the electrical plug. TCMs are easy to take out and replace hopefully that's the problem. I could take one out of my other Sprinter and try that. But maybe not a good idea?
Yes, testing is the best way. I don't know much about testing or have Sprinter shop/mechanic here.
Sprinterair
Hijack your thread here for a few words , I do have a personal "fleet"of MB vehicles which are most using 722.6 tranny ( I called the Hercule tranny) and did a lotsa works on them including modification the governor plates for better shifting, change seals ,conductor plates , shift solenoids blah blah blah..................... This type of 772.6 can last up to 300K miles before rebuild if property cares .
Your tranny works before changing new fresh fluid and should work after , problem mostly when instrument display doesn't show tranny positions or limp mode is comontly came from improperly seat of tranny plug to conductor plate when change to new one or some case when new install new plate .
I had change my new conductor plate and did happen same like your but clear trouble code with iCarsoft MBII at a easy click (F2) and I don't think ya have problem with TCU at all .
Good luck bud.
