toast
The "Euro socket" is just the turn signal socket intended for these european style housings. I was originally under the impression that the sockets are the same as USDM, but apparently not. It is slightly different, and for whatever reason, if you use your USDM turn signal sockets, the lights will hyperflash. I will have these euro ones purchased separately and installed for you.I'm interested, but have some questions:
What is a euro socket and where does one get them?
Do these plug into the stock wiring connectors / sockets?
How do the high beams work? Are they a separate halogen bulb or does the output from the HID move?
Is the factory (motorized) height adjustment retained?
These housings plug right into the stock harness for your headlights. It's actually one big plug and done.
The highbeams illuminate the regular highbeam bulb and the projectors brighten as well.
The factory motorized height adjustment is not retained because unfortunately the motors cost more than the housings. There isn't a demand for the adjustments once you install these and manually adjust them with the included knobs on the back. The connection to plug in the motors is still in the back of the housings, and you are welcome to try and move yours in since the wiring is there, but I can't guarantee it will work because I have not tried it. The manual adjustment is done by aiming your lights at a wall like a garage door and reaching your arm behind them in the engine bay. There is a knob to tilt them and raise them up and down.
Please let me know if you have any more questions, placing a set of orders tonight.
