sanomechanic
Had installed a 5 channel amp . ft door speakers and tweeter, rear 3 way 6x9s and a 10 inch sub. All JL Audio. Used a high to low signal interface. Huge improvement over stock but had some hiss noise and the sound quality was hit and miss. Removed the high to low interface . Installed a JL Audio FIX 86 today to clean up the signal coming from the 10 inch screen audio system. WOW what a difference. Incredibly clear sound!!!! If anyone has stepped up their audio. This fix 86 will work for any sound systems. Highly recommend it. or if you only need 2 channels a FIX 82 will do. The frequency curve of the factory MBUX is crappy and needs cleaned up. It was designed to drive the garbage speakers the van came with and does not give a proper signal to an amplifier. the FIX corrects it
FiX-86
OEM Integration DSP with Automatic Time Correction and Digital EQ. 8-ch. Inputs / 4-ch. Stereo + 2 Subwoofer RCA Outputs The FiX® 86 is a state-of-the-art digital signal processor engineered to deliver outstanding sound from factory source units, while retaining OEM fader control. Unlike...
www.jlaudio.com
FiX-82
OEM Integration DSP with Automatic Time Correction and Digital EQ. 8-ch. Inputs / 2-ch. Stereo RCA Outputs / 1 Digital Optical Output The FiX® 82 is a state-of-the-art digital signal processor engineered to deliver world-class sound from factory audio systems, without replacing the OEM source...
www.jlaudio.com
